Adding Ventilation
« Back To AskARooferMark in Texas asked:
My house is a 2 story and roof is improperly vented. The upstairs room is a cathedral ceiling that extends about 6’ down the front slope and is crammed with batt insulation. There is really no way to add ventilation near the ridge without taking out the insulation. My question is, will a vent work on the front slope if it is 6’ from the ridge row? The slope has a 22’ rafter length. I'm considering a solar power vent, but would prefer turbines. Thank you
Alex just going off the little bit of information provided, there’s multiple different options. I would look into gable vents, soffit vents, and potentially ridge vent. The goal is to find the vent that would vent across all studs and provide adequate air flow to vent the space. Typically you’d want a vent to allow air in and then a separate source to allow air out. Soffit vents are typically the best option for the inlet combined with a ridge vent for outlet. Gable vents are great options also. I’ve attached a link to all three types. The power vent the homeowner referenced would only move air in the one cavity between studs.
Here is a link to a continuous soffit vent example (we are not endorsing this product and know nothing of its reliability, it’s merely an example of a continuous soffit vent application)
Continuous Soffit Ventscanplas.com
Here is an example of a ridge vent (we are not endorsing this product it’s merely an example of a ridge vent).
What is a Ridge Vent and When Is One Usedgaf.com
Here is an example of a gable vent (we are not endorsing this product it’s merely an example of a gable vent).
How to Install Gable Vents in an Attic? - A Guide!vulcanvents.com
Henry Staggs responded:
