Attic Ventilation
May 17, 2022 at 10:29 a.m.
What type of intake ventilation do you recommend is best for attic ventilation?
Intake Ventilation should be down low in the attic.  Exhaust ventilation should be near the ridge.  Soffit vents are usually ideal for the intake vents.  Intake vents down low allow air to flow freely to the Exhaust vents at the top of the attic. Soffit Vents are ideal if possible.  Roof vents mounted low on the roof are also adequate for attic ventilation.
Exhaust Vents mounted high on the roof will establish a passive flow of air in the attic.  Ridge Vents are very satisfactory for exhaust air.  Generally, a 50% intake and 50% Exhaust air will give you ideal air flow.  The formula for intake / exhaust air changes with different climate zones.
Hopefully, this information will be helpful when deciding to install your attic ventilation.
Your Friends at AskARoofer
