Bulge Where Addition Meets Existing Roof
July 26, 2023 at 7:39 a.m.
Jason, a homeowner in Texas, asked:
I am in the middle of a remodel and addition. We are basically adding a rectangular building to the back of the existing house to form a "T" shape. The shingles were just installed on the addition and tied into the existing shingles. There is a bulge at the seam where the new shingles meet the old shingles. The roofer is telling us that this is standard. Is that true?
July 26, 2023 at 7:40 a.m.
Mike from Texas Traditions Roofing says:
Hello Jason. Thanks for reaching out to us. It’s always tough when you’re tying a new roof into an existing roof. The bulge could be they didn’t remove the existing shingles and laid the new shingles on top of it and tied in. It could be the new shingles are thinner than the old shingles and it doesn’t lay smooth or they come together. Do you have any pictures?
You can reach out to me if you would like at 512-839-3325.
Thank you,
Mike
July 26, 2023 at 4:10 p.m.
July 26, 2023 at 4:11 p.m.
After reviewing the photos, Mike from Texas Traditions Roofing says:
From the pictures I don't see anything I wouldn't expect to see in a closed valley installation. The shingles at the lower arrow is not going to be as smooth as the main field because the shingles forming the valley terminate under the shingles to the right of the valley. The shingles at the upper arrow is where they had to tie in the new shingles to the old shingles. That area can be rough because they have to lift up the old shingles and get underlayment underneath to tie in the new addition to the old addition. That can bend the old shingles and creating a rough look. It's difficult tying a new roof into an old roof and having the old roof transition smoothly to the new section.
Mike Pickel
Marty from Go Roof Tune Up says:
Congratulations on getting a nice room addition to your existing house.
Any time you connect anything old to anything new you have the possibility of it not looking perfect. What the photos show could be caused by the substrate, plywood, not making a smooth transition from old to new. Or it could be that the Underlayment, paper under the shingles, is causing a “bulge” effect.  Whatever the cause this will likely become much less noticeable after sometime has gone by. This will not effect the longevity of the shingles and the longer you enjoy your new room the less you will look at it.
The only thing that you can do at this point is have the entire roof on that side of your house removed and redone.  You won’t gain any benefit except to try to win the “Battle of the Budge.”
Marty
Brad from Beldon Roofing Company says:
Yes, it seems to be accurate. When opting for a closed valley installation, you'll have multiple courses on one side. If the customer has any significant concerns, they can consider hiring a home inspector to ensure the installation is done correctly. I hope this information is helpful.
September 22, 2023 at 10:14 p.m.
riskar56345
It is not unusual to see a slight bulge when new shingles meet existing onees mainly due to differences in age and wear. In most cases this is considered standard and with time it tends to become less noticeable as the new shingles settle and weather. However if the bulge is significant or persistent it might be wise to consult another roofer repair  to ensure proper installation and assess if any adjustments are needed.
