Elastomeric Roof Coating on a Balcony
May 18, 2023 at 12:45 p.m.
Allisha from Bloomington, IN asked:
Can elastomeric roof coating be used on a balcony? Is it walkable?
Hello Allisha,
Below is what our roofing expert John Kenney from Cotney Consulting Group had to say in response to your question:
Allisha,
I do not know what your balcony surface is. Still, an elastomeric coating can be used on any compatible surface, as the coating manufacturer recommends. It is recommended that sand is broadcasted onto the finished coating layer before it dries so it is a rougher surface for preventing slips. The manufacturer will have the information required for that mixture.
Thanks for using AskARoofer!
August 5, 2023 at 10:26 p.m.
Henryjohn
If you're facing a leaky roof issue and need expert assistance, consider contacting Reston Roof  Service. Their team of professionals can inspect your roof, identify the root cause of the leak, and provide the necessary repairs or replacements to ensure a durable and watertight solution. Taking timely action with the help of Reston Roof Service can help you avoid further damage and maintain a secure roof over your property.
