Leak During a Storm
July 21, 2022 at 8:56 a.m.
Nicolesharples97
James from New Jersey asked:
We recently had a rainstorm and there were no leaks but all of sudden, there was water coming from above our stove. We have a microwave above our stove and there was only a little bit of water inside the microwave. That's why I'm thinking it was coming from the exhaust vent. How can I confirm the source of this issue? Is this an issue that would have long-term or severe costs?
July 21, 2022 at 8:57 a.m.
Nicolesharples97
Below is what our roofing expert Lorie Herman from Farrell Roofing had to say in response to your question:
 First -Where the exhaust vent comes out of the roof verify there are no screw holes, cracks, or nails backing out. If there are refasten or seal the vent where it is exposed with caulk (all-purpose sealant) or roof cement on the roof itself.
If the leak area is not found and repaired it could cause rot on the roof system, however, a repair of the things we listed above are a minimal charge.
July 22, 2022 at 9:47 a.m.
Nicolesharples97
Below is what our roofing expert John Stout from Go Roof Tune Up had to say in response to your question:
On occasion, water will puddle and the leak will not be observed until after the rain ceases. The leak is showing up in the area of the exhaust hood and vent. I suspect, that the source of water intrusion is related to the exhaust vent. It will be necessary to inspect the vent on the roof. It may be deteriorated or damaged and need to be replaced or repaired.
This is an issue that could become an expensive repair if not taken care of. We recommend having a roof professional look at the problem and initiate a proper repair.
If you do not have a roofer that does your regular maintenance, go to rooferscoffeeshop.com and request a recommendation for a qualified roofer in your area.
I hope this information is helpful. There are not many things more irritating that a leaky roof.
Your Friends at Ask A Roofer.
Tremco - Banner Ad - Is your rooftop safe?
Westlake -  Ad - Design Canvas (AAR)
