Leak Inside Due to Roof?
April 21, 2022 at 1:39 p.m.
I have a leak on the inside wall when it rains. I believe it is coming from this box under the roof. Please help. Thank you
April 21, 2022 at 1:40 p.m.
I think you are correct.  From the photo that you submitted, it is very difficult to see clearly the shingles and metal edge.
A common problem with “Zero” overhang at a rake edge is water going under the shingles and entering the house.  The photo shows the metal edge as not being tight to the shingles.  Examine this area.  I think the solution will be to replace or repair the metal edge.
Thank you for your question.
Regards,
Your Friends at AskARoofer
TopShield (SRS) - Banner Ad - Ice & Water
