TPO Membranes
February 22, 2023 at 5:19 p.m.
Joe from Ontario asked:
I am looking for a TPO liquid to apply on an aluminum flashing so that it can be heat welded to a TPO membrane.
February 22, 2023 at 5:20 p.m.
This is what John Kenney from Cotney Consulting Group had to say:
Joe,
I am unaware of any coating you can coat metal and heat-weld the membrane to it. You have a few  options  to do this if you want to use aluminum as your cover metal:
  1. Fabricate a cleat from TPO-coated metal with a raised edge that you can weld the membrane on, then snap the aluminum as a fascia piece.
  2. Use TPO cover tape to seal the edge flange into the TPO membrane.
  3. Purchase a prefabricated metal edge that integrates with a TPO system and aluminum edge metal.
